Nah the difference I don't lie about it haha. top bloke white knight.
Nah car will probably be going up for sale tomorrow. I'm set on getting an evo now.
By the time it sells plus saving until then I should have enough
I don't lie, I'm just single and heart broken. Forever alone, single4lyf, singlelworks
WTAC I think only fun if you know ppl driving and can hang..or better yet driving yourself.
My wedding will clash with next years..
started shopping for 2014 WTAC tho,
thinking 300ish cut some weight, lots of aero, and flar the f%^k out fo the guards to get biggest rubber I can..should be fun
aaron i'll give ya 7k
how much did ya buy it for anyway?
Nah I'm gonna put it up for something stupid like 17-18 k. Someone will offer what I want eventully
The going rate for the built ones are like 14.. And being honest mine does go abit further than just built so I guess I wouldnt be asking too much
I have red ones...they looked okay...but I expected better. Made it look like brake lights / rear parkers, like you're looking at the back of a bike, which ruined things a bit. Green looks much better in real life than red, works well with black and gold and is slightly less illegal.
Merry Christmas
should get copper spec flashing red/blue
I wants socket set. Reccomendations on where to go what brand or are they all the fkn same?
Kinocrome, as for places, shop around all tools/auto parts store.
GTRs are good and all but too old to buy now IMO, even when I spoke to Vu about his 34 he said he had to replace some major parts that were rusted the same as my R33 :\
Rusted?
DAFUQ you on about? Mine had no rust!
A 6 and a 33R similar weight? No chance .. ive driven both and the 6 feels much lighter, even though the 33 R ha more power.
Maybe a 7 might be nearing the weight of a 33r but I doubt it
Seriously go see a doctor. You are fked in the head
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
