for the price difference of a bees dick.
i'de jump onto the following; cheap and will handle over 800hp
Walbro 416LPH E85 pump (Injectors online)
Fuel Rail kit that sits under the intake mani (injectors online)
ID2000cc (injectors online)
if you speak to scotty, he can get everthing in for REALLLLY CHEAP..
ive already got the pump so you can have that cheap if you want as i never put it in.
toby if you can put it on SAU Vic I will love you long time.
SAU VIC Facebook page?
Can do that.
When are you going to get FB you kent. At least you could check up on comments on your own ad if I put it up
hahah fk that. i dont think the missus will let me anyway lol
yes im whipped.
Yes haha
Who is this girl? How do you know her? Why did you add this girl as a friend? Why is she posting on your wall? Did you ever like her?
OMG Aaron are you cheating on me! Why are you keeping secrets from me!
LOL
Yes haha
LOL
haha read it in a curry accent, makes everything funnier
thanks brah
Bike looks good Birds, f**kin need one again :(
Aaron needs more low
Jonoe that cars gay
Alvin new plates?
Justin yes you do
Anthony I only eat maccas when I'm at home because I'm in the shitter within the hour
oh and Dezzmang your main man got taken out by a newb on Sunday :( at least it gave Webber/Vettel a chance to catch up a bit and make things interesting
Jonoe that cars gay
Alvin new plates?
Justin yes you do
It potentially needs to pass a roady why would I lower it again.
And yeh Alvin's plates are my old ones
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
