I have a magnetic TAXI roof sign that plugs into a cigarette lighter socket. Was gonna stick it on the roof of Alvin's car when I was driving it around. Even without drunk idiots in the city tried to wave me down.
why are you getting so angry? lol not like you have to take my family around haha
no man lol. why would i go backwards
Haha not angry just want to make sure you are not selling up for reasons other than your own. Cause I can picture in 5months time you posting on wasteland regretting the sale haha
theres a whole bunch of factors, just one main one was the ability to take passangers.
i dont really want to track it because of the paint on it.
its kind of retarded me rocking up to work in a bright orange 200
I want something that flies a little less under the radar.
and to be honest i just think its time to get into something else.. i've driven it enough..
the car is that popular, as tony said has a lot of 'fruit'.. if im not enjoying and appreciating it as much as someone else will any more, they may as well have it.
Looked at a few Evos on carsales yet?
Share us a few links on some that take your fancy
Had a look to get a rough idea on prices, but not really looked into-into it.. No point as what if it take 6 months for me to sell the car, if by then I have a company car I might just give up on the whole evo idea and buy anOther house first.. Then buy an enjoyment car.. So I'll just see how it goes, if time comes and it sells tomorrow for example, then I'll start looking
just the one investment. its under mum n dads name, i just pay the excess part of it. tenants take care of the rest. and so does dad.
1 thing i have no idea about is investment properties lol.
It's meant to go in my name later on - how far thats true and whether he actually will put it in my name is a different story.
I understand the rocking up to work bit, I use to feel a bit weird when people stared / greased me off in my old car still that wasn't the main reason I sold it I just couldn't be f**ked with the cop stress around Knox and as you said got over driving it.
Whats the chances of a work car? wouldn't they let you know when you started?
dem rims: what are they?
That's gonna cost a fair bit to do
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
