I understand the rocking up to work bit, I use to feel a bit weird when people stared / greased me off in my old car still that wasn't the main reason I sold it I just couldn't be f**ked with the cop stress around Knox and as you said got over driving it.
Whats the chances of a work car? wouldn't they let you know when you started?
dem rims: what are they?
Let the old people drive their camry's. They hating cause their wife makes the car choices haha
It's meant to go in my name later on - how far thats true and whether he actually will put it in my name is a different story.
That's gonna cost a fair bit to do
+ 1
Not 100% sure. But there will be stamp duty costs. So unless his going to pay $10K + to transfer the property, and there will also CGT Tax consequences.
oh wells
Lol ok so your all saying that I shouldn't sell my car to benefit others by being able to have them as passengers..
But on the other hand you don't want me to sell because you think it's not a good idea.
Why can't the reason I want to see the car, is because I just want to?
And it's my dad, lol I couldn't care who's house the name is in. I'm pretty sure I'm raised by them for 22 years without any expense from myself so if this is the least I'm doing then so be it.
SSOOOOORRRYYY if none of you have positive relationships(or enough of to one) with your parents to help out a little bit
Dw man we still love ya :P
Lol stop bring a girl and over analysing everything
Just giving out free tax advice brah
Always good to be aware of what you can and can't do
Guest
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
