Still a daily, as I have no other car lol
Yeah will see how it goes when I install the turbo, May need to feed the throttle out of corners when I track it
I think you'll be fine with the invos for now, if the highflow is only going to get you 250 it should be alright with the boat!
Toby, arre you turning your car to RACECAR?
Yesp, slowly but surely..
SS2 brah. Probably 270-280rwkw apparently
you're azn, you'll never see his level...
what tyres ham's got?
Well at least he's got 'panaramic' / 'widescreen' view and can anticipate the track.
lol Jamie
lol... and isnt 280 a little too much?
I'm thinking maybe should have gotten the same turbo as Birdman. SS1PU
Iuno how you lose traction in 3rd, even with dunlop 245s in 2nd when they're warm I can pull 60km/h role and not lose traction if the road is smooth, if I take off from low speed in 2nd then it'll just spin tho
If tyres are cold or I havn't been fanging it around to warm them up it'll lose traction at 50-100 in 2nd feelsgoodman
Group buy nt05s gogogo
i'm planning on hitting nats in STD rwd.
did it last year and came 2nd to richo on the track..
so think got a decent chance this year.
but the airport run...i'm going to get demolished! what with my little 180 kw
how is your car so devoid of traction aaron?
even with 320rwkw I have full traction in third
You all drive heavy as f**k boats. If the tyres are warm I have traction. Just when everything's cold I don't. Plus the turbo is kind of nothing nothing nothing then bang 270
Probably also has something to do with not having it aligned yet
<3 SS1PU, so streetable! And happy to take the V8s above 100.
As soon as I sort out my fuel economy issues I'ma get that E85 tune for the super responsive 300!
This...comparing apples with oranges here. Even on the same cars traction is a totally different story with suspension setup and power delivery, let alone totally different chassis and gear ratios.
ya even with my power I could spin in 3rd when I had cold streets
semi's fixed that.
nt05s dont look very safe in the wet.
I did mt buller rd in the rain couple years back with NT05's and 280rwkw... barely saw below 5k rpm the whole way
they did VERY well
This... is what I was getting at..... ;)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
