Forgets myki at home, has to spend $16 for another. I want paper metcards back...
I don't want to always keep a plastic card in wallet for the rare chance I have to catch public transport...
$16?!
And no more metcard?
In London, they have a thing called oyster and it works and they also have paper ticket for whoever doesn't use it everyday.
Why can't it be same here? This we won't know.
Speaking of Alvin, I turned his wagyu mince into a kg of spaghetti.
Will report back with taste. Already noticed it clumps more than regular mince and has less "juice" to drain.
$16?!
Yeah it's like $6 for the card and minimum $10 top up. No paper metcards from the stations i believe.
Oyster works in london cause everyone catches the train. Not here where you have people travelling from suburbs into the city :/
Cool vid. Have a soft spot for rx7s
same, I would of probably owned one by now if the motors were more reliable
http://www.ebay.com....#ht_1218wt_1163
if only the fronts were more aggressive
woweee
http://www.ebay.com.au/itm/19-Work-Meister-S1R-Rims-wheels-JDM-Pirelli-Achilles-Tyres-/320974007125?pt=AU_Car_Parts_Accessories&hash=item4abb8aab55#ht_542wt_1397
Flared and an extra 2 degrees or so. Yum. Sank you aaron. Mind you, the guard in pic was flared by hand. LOL. Honda quality
Have u had it aligned? Looks like the drivers sticks out more. When's it's all aligned bring it round so I can even it out, plus I need to redo the passenger side to get rid of the lip
Fuuuuuu
Waved into a booze bus which came out of no where. Pass the breath test, "pull over to the side please and pop the bonnet"
Asks me if car modified, say nup apart from exhaust. Looks at engine bay. Not helping my statement with a 52mm alloy rad, thermofan controller with led's and air pod lol.
Shines torch over engine bay, then looks at front tyres and reads the Japanese tyre placard.
Says all good and let's me off.
Thank god for staggered fitment. Rears would have been too wide.
Haven't had a cop encounter for 2 years lawl.
/csb
Allignment tomorrow. Left pic is previous (before flare) aaron, right is after.
Theres more camber on passenger, i think i'll get the right side set to the same. But I have a feeling the drivers is flared out more.
The shape of the guard is way better on passenger (the one you did by hand) Flows better with bumper.
Been taking like 1 per day.. only because I hadn't been working out for a week due to some stitches in my chest from a small op I should try and get onto it twice a day if I can withstand the smell / chunkies :P
I'm doing 2 scoops not 3 so guessing around 4-5grams of creatine with the mass gainer then taking pure creatine around twice a day (5 grams again) I should be doing it 3 times a day though considering it's my "loading phase"
Currently around 75KGs getting there slowly, I was under 70 when I started
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
