you think london is good... you should see singapore's system!
whole week i was there (public transport at least 4-5 trips a day) cost me a grand total of $12 SGD (like $9 AUD)
no graffiti
pregnant mrs was offered a seat on EVERY TRIP
no rubbish
no f**kwit drivers to strike or go slow/stop near stations as part of unjust union action
longest wait for a train was 4 minutes
just borry my guard roller martin
lol. you're just lucky you're still alive..
some rails are secured using cable ties.. For the past 3 months, the whole system has been bugged by train cancellations and delays.
I ride the push bike in singapore. so small anyway. so flat too.
no graffiti
no rubbish
sounds like HK
payed 30$ for high speed transfers to hotel from airport and 3 days unlimited travel, airport trains every 10 min, otherwise longest wait was 2-3 min.
as for a guard roller, I actually own one..just too lazy to use.
16k for an r6.
2.8k/annum insurance.
i'll be riding my push bike thank you v much. and the motorcycle licensing...
there's class 2B 2A and 2.
2B : Limited to 250 and under.
2A : Limited to 400 and under.
2: No limits.
But do get 2A, you need to be on 2B for a year, To get 2, you ned to be on 2A for a year.
So its 3 tests.
sif 16k for an r6
also, lol @ that being harder than vic bike rules here you can ride what ever the f**k you want after 15 months.. I disagree with how easy someone can get on a 1000 yet not drive a turbo skyline
you can ride a 9 or 10 second bike at 19 years old yet you cant drive a 14 second skyline until you're 22
/vicroads logic
How's my boosts going? Haha
officially sick of it..
stay tuned for next sesh. please no more boosts.
Get some Cadbury Milk chocolate and we will make a chocolate fountain and dip strawberries into.
nohomo
sounds like HK
Its really not hard, if u don't are about paint just ghetto it with a pole
Lol I have a Chico fountain
Haha awesome!
imo strawbs are still sour.
That combo is awesome, I eat it all the time in the restaurants. Wait till the chocolate cools and hardens up then buon a petit.
Saw a certain other member who ahd done that on his..mmmm bumpy.
smother it is the smoother aero, and I will be seriously looking into that over the next 12-18 months
looking at these guys work:
http://www.sxdevelopments.com.au/2012/05/15/sx-developments-s14s15-featured-on-the-lowdown-com/
Well yeh those two cars have had a lot of customization done. The s15 is very recent iirc..
Well if u don't want ripples I'm happy to do it. And I'll do it without cracks aswell
http://www.sxdevelop...he-lowdown-com/
Building your car up to take out Richo next year? :P
year after.
wedding/honeymoon will rule me out of wtac next year.
looking to build up Aero chase 300ish+ and get bigger rubber
With a lighter car should be fun
year after.
Sell your car and buy Aaron's? :P
i wish i had that kind of money you guys have.
Once you become Engineer brah
year after.
You should buy my car, it's already 3/4 way there lol same body kit just add aero fins.
And bigger injectors and 350kw your done
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
