Drive through Springvale windows down, random comes up and says nice ride man...thought he was trying to rob me...it's just been that long since anyone has received a compliment in an R33.
Bet you get an EPA in the mail
It has it in the video name :D
Oh.
I'm on my phone can't see that shit.
Called the engine builder who built the car and engine. He basically said to me I'm an idiot for selling it, and the previous owner was another Idiot to spend so much and sell it to me..
Apparently a "very serious" build with no shortcuts on this one..
Now I don't know if I should sell it
Once you have decided to sell - do it.
I lost too many nights of sleep debating selling/not. Took me a month to post it up... But overall glad I sold it... On to bigger and better things as they say.
That said I miss the car, bad.
After driving a mates GTR @ DECA on Sat, just reaffirmed just how well my car was setup with a no expense spared attitude.
Not saying my mates wasn't done right, his is a daily so it needs to be driveable and not have 1.5 way diffs like mine etc.
Ah :(
This isn't normal for an R33 Gts-t
Most be an ulterior motive
yeh its already up for sale anyway. So i guess I'll just keep it at the price its at and if someone gives me an 'offer i can't refuse' then it'll be goodbyes.
Ah :(
BUT: ^^^ that is what I dont want happening. this car handles like its a go kart or something lol
Haha got the same compliment yesterday. Hang in there!!! Only a couple more years until all skylines have rusted away haha
lol... every sinngle compliment I get for my car starts with "I don't normally like 33's BUT............"
Yeah I got told the same, and now it's "I don't like Fords but.."
"I still don't..."
Haha!
Oh.
Lol nice. Put up the price. Got tuner cred now!
lol @ how much R33 were selling for nearly 10 years ago. And they had interested buyers!!!
http://www.skylinesa...497#entry356497
10 years ago a R34 GT-t was unheard of and fetched well over 40k!
Oh it'll happen alright, every day for MONTHS!
http://www.skylinesaustralia.com/forums/topic/17139-fs-1996-skyline-gtst-ser-ii/page__pid__356497#entry356497
Haha Dezz did well. Sold his at the peak of the boom. Stocktraderdezz
R32's used to be $15k. Now they $4000
It's hard justifying a respray which costs more than the car :/
Guest
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
