Wait til you get on a bike, you'll be saying the same about cars.
Yeah looking forward to it, just have to find one (that I can afford Dezz :P ) and get some new gear.
oh god, ok
that one I have on the front of my rocker cover and is 4 or 5 numbers
Ah ok yeh that looks like its it then. Mines next to the engine number, hence why I was askig where the engine number was! Thanks man! And sorry for being confusing lol
haha he ust must ahve been prouder of my motor build so put it out on display ;)
dat return flow
Means ill have to lose my front auto spoiler and put airbox back on :/
and hopefully it doesnt hit the foglights either :sick:
not sure if pro's greater than cons...
Why put air box back on? For EPA?
I had to remove my indicators for my return flow haha, still haven't bothered to position it correctly so I can put them back in.
yeah FMIC + airbox is an easy way to get sent for EPA test and i dont want to be removing turbos and injectors again...
I love my pod. Personally I think the airbox is a bit restrictive; definitely noticed a power difference after switching between them a couple of times. Probably helps that my car was tuned with the pod.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
