cant, the rears would look silly as plus I need 19s because I'll be doing a 6pot brembo upgrade at some stage down the track
also, STRAYA KANT.
How much will this set you back?
How big are the rotors on your car out of curiosity?
I don't get the re agents and cocaine reference, but anyway I'm unashamedly a fan of iPhone and almost every business is working towards it and being compatible
Not hating on Samsung or whoever never tried it but as they say if it ain't broke don't fix it
I used to think phones were the best, even after putting up with it constantly crashing and it not syncing music like it's supposed to
Then I got an S3
Lol iphone.
So the s3 is good? Full review please. I'll consider buying your bike
Reading this right now.
Always find the Motor Tuner challenge intradasting
Sub $75k cateogry dominated by 86's and Golf's
Would have been more interesting if they did it on a bigger handling track. I.e. winton or something
They're the only reason I buy Motor otherwise I wouldn't bother buying/browse it at all.
86/BRZ and Golfs seems to be next budget 'Tuner' cars.
You can get a front brembo 6pot kit with braided lines and brackets for just a tad over 2k for my car
322mm stock rotors on the GS, brembo kit comes with 355mm rotors
Straight from a review of the GS:
Braking: With the same brakes as the XR8 (322mm and 302mm discs, sliding calipers), the 315kW GS is under-braked in our view, even as an entry model.
Feel through the pedal is soft, making it poorly matched to the ability of the engine. A shame, then, that the GT's four-piston Brembos are no longer an option on the GS.
Basically they didn't allow brembo factory upgrades because then you would be getting a GT for 15-20k less.. engine and everything else is the same only difference is the "315" and "335" tune which goes out the window anyway now that mines tuned to what? 440kw? lol
Then I got an S3
Lol iphone.
Was that 3? My 4 has been only phone to last me 2 years with zero problems I use my phone flat out to
fyp
LOL!
also, STRAYA KANT.
Agreed with the haters on iPhones.. all the f**king smart phones these days have big touch screens, take photos and have 'apps' zomg soooo different!! apple is too mainstream? I don't care because my car has integrated iPhone connectivity so I can have everything display on my screen in the car and use steering wheel to change tracks etc. If I had an Android I'd have to plug it into the 'AUX' connection and use the phone itself to change tracks.. that alone is enough for me to go Apple really.
And same as what Alvin said with the Ipad wifi model, just use my phone for reception if I'm out and abut.
Oh and Hamish you're right about the customer service / replacement phones, pretty good. I used them a fair bit at my old work.
Stick to ya Bob Jane wheels :rofl: STRAYA KANT
Android for the fucking win! KANT!
That actually seems quite cheap
link?
Newsagent brah
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
