can someone scan their motor magazine and post pics?
Got a few modded fords and holdens too
One of the fords had 558rwkw. Yet still a few seconds slower than a 100rwkw 86 :P To be fair its a small track
LOL had to look twice at that before i realized.
haha yeah ofcourse it would do shit on a small track! Wonder what it would do around PI :P
Those kws are for dyno queening
Yeah pretty much or drag spec, assume its the 5.0l coyote?
So the s3 is good? Full review please. I'll consider buying your bike
Not sure if serious
Was that 3? My 4 has been only phone to last me 2 years with zero problems I use my phone flat out to
Had 3 and 4 both froze a lot as well as other issues
Hooked on frontline commando sick game and works perfectly on my android
A+
Will sus it out, I'm over temple run
friend asked me to go get motorbike license with him in a couple of weeks >,<
tempted!
Do it.
And buy my bike
<3 varrstoens
Dooo ett! Matt black. kgo
Yeah no doubt. Disappoint with the 86 1/4 time though. 13.98 with 168rwkw.
Haha only issue is apparently they dont clear brembos in the sizes I'm looking at.. I dont have brembos yet but was looking at them down the track.. hrm.
And yeah, light stiff car = hard to get power down not designed for drags I guess
Guest
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
