Lucky bastard, so how did you get into that did you study programming? develop software or??
I has year 12 only...
started uni, Chem eng, hated uni with a passion due to having no Fkn idea what I wanted at the end.
I just did what ppl said, oh you has good results u should do blah.
I grew up on a farm no idea what the options out there was.
so thrown out of uni as I was bored, I got a job for a telco help desk in fact a couple desks up from paul33
did well, went to work for a dot com start up..showed some skills blah blah blah travel lots
so I would like to say self made..
LOL man my 1800kg boat ain't designed for corners :P
STRAYA !
f**k I hope not as I will be going head to head with you!
aight, should give me some what of an indication just imagine 1cm off on each.. when can i try? :P wish they were 19s!
Alvin's! Aren't u after some grip? Surely you'll have more with 18s it'll definitely be cheaper aswell
ah okay cool cool, I studied I.T for 2 years after year 12 been in the workforce for about 2.5 just wondering about career paths down the track.. hard to think of many things other than infastructure management / i.t manager stuff :\
ATM just server / desktop / app support type roles..
Don't worry won't be taking my whale on the track you'll be up against me on the 1/4 mile tho
I took your advice, have had red meat for the past 4 days. I feel f**king fantabulous. Maybe take your own advice..
Watch now Ive jinxed it
Been hitting up the Vitamin C + water + good sleep too?
My advice probably works well for other people, but because I have next to no body fat and keep sharing beds with people who STEAL THE BLANKETS, causing me to wake up shivering...my advice will only take me so far :(
re work...right place right time, right skill set. I was a lucky prick end of story.
been one company for 12 years next week. started bottom level support
talked my way up since then.
i've worked hard but been rewarded such as well so no complaints
re track.
I would be keen to see it go round...(more would love someone give me some keys to take one round.)
i recon I could give run for your money on a track...straight line...i'm doomed against not just you...so many cars.
Yeh water and sleep is good! Happening a lot more since I been eating well. Also got on this stuff called orange triad by controlled labs.. Immune joint digestive system multi vit. Took it for the first time this morning just one to see if I'm gonna react. So far so good..
I'd probably get half a lap in with the current brake setup :P not taking it on the track just yet need a few more things setup before I give it a go. Would be fun sliding it around though!
Just airport / show and shine this year for me
Wrapped roof looks poo, me no likey. I am happy with how the car is now, could use a front lip of some sort.
Off to Japan next weekend. Shopping list includes, cusco lower control arms, nicer foglight globes, Carbing strut brace and anything else I impulse buy
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
