Has anyone watched The Raid Redemption?....Sick movie!
http://www.imdb.com/title/tt1899353/
Seen it. Can't say I liked it as much as other guys.
The new Judge Dredd movie seems to be a similar style to this judging by the trailer
ah nice they'd go down pretty fkn sweet with some good scotch
need to find some cohibas for new years eve
They stock cohibas as well, they pretty much stock everything
www.bestcigarprices.com
Just make sure if you have stuff ordered they clearly label the weight of cigars only as thats what the duty is calculated from and it ain't cheap at $436 each kg
fitted my focus RS insert today!
Already looks heaps better every with tape still on :P
Last time i smoked a cigar i forgot it was a cigar and inhaled it, then coughed my guts out for the next 20 minutes.
typical arab, probably thinking of shisha while you doing it
no... the money i save in hospital bills will easily outweigh your petrol savings
Private health insurance ftw
Well I just saw this on the Herald Sun...
http://www.heraldsun.com.au/news/national/motorcyclist-wills-high-speed-crash-into-a-trucks-trailer-in-south-carolina-caught-on-film/story-fndo48ca-1226474174054
I know it's his human nature / reaction to a traumatic event, but it's pretty retarded to say you're not getting back on a bike because you're a husband/father etc. after you have an accident. Did he think he was an invincible husband/father beforehand? Since when have motorbikes not been life threatening? I wouldn't ride one if I had kids.
False.
There is no aerospace design industry in Australia. There is Boeing in pt melb but that is just a manufacturing wing. Designs come from America.
Apply for mech jobs and hr will knock you back as they want mech eng not aerospace.
Have couple friends who did aerospace. Had a real hard time finding jobs.
Was about to say same thing mates sister couldn't find anything at all
U gonna be rich
If I can get a job... ! LOL :(
False.
Haha yes, this.
Dunno about getting knocked back from mech jobs though (granted I haven't applied for grad positions, still got 2.5yrs left since double).
Most people from companies I have talked to have told me that while obviously it is/can be a factor, they're not too fussed; and it's more the person themselves. Of course when it really comes down to grad positions, will have to see (as apparently your mates have gotten knocked back, gg). But yeah, I was talking to Holden purchasing program manager, and he's a chemical engineer by trade iirc.
He gonna be at NASA brah
Yeah monies overseas unfortunately.
Luckily for me I actually don't mind / would like to head overseas :D.
Maybe I should double major in another language... like german... hmm...
OT
Damn only a broken wrist and leg :O
Edited by kaitoukid
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
