Tried going in a servo with helmet on coz cbf taking gear off just for few seconds, soon as door opens kunt out of nowhere yells out "stop right there remove your helmet please!"
Thought I was gonna get shot down..
Chill brah
Wear a burqa, that's fine
He was more scared when you took the helmet off, wasn't he?
yes Riq
you weren't aware.... of something that has stickered on the window of every bank and most service stations in austraila for the last 30+ years?
i haven't been around for 30+ years. sorry
yeah it's f**ked
thats problem i have =/
Shieeeeeeeeeet that's not good...
http://www.metalspinnersaust.com.au/metal-spun-wheels.html
Take it to that joint, and see what they say. They could probably remove the clear for you, polish, re clear. Or they'll just make you another lip. Lol.
Not sure on price. Give em a call.
Chill brah
only because you're a unit, they still let me in the shop with helmet on :(
http://www.metalspin...pun-wheels.html
Better off going to an independent metal polishers and just have them polished (cheaper usually)
Has a better shine because the clear will hold back some of it, and there is always a chance to have it peel again
sweet thank you man, was looking for that site earlier and couldn't remember what they were called!
yeah ill have to have a look around - i know there is one guy who told me he does complete restoration for 400$ per wheel.. so if i cant find cheaper i can always keep that in mind..
Id prefer the clear on it to be honest, i think its too shiny without it on those wheels imo
lol probably been robbed by a helmeted dude before...
Just peel it all off and re-clear coat it?
good tattoo
thinking of getting a tatt on same area. working on a "design"
lol id swap for that!
my old man has a detomaso pantera gts but he lives in syd.. i live in melb, see it like once every 5 years as he keeps it in storage
he got it for just over 10K in the early 80s and it had water in the diff and transmission..
Edited by bluejeans
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
