Yeah, man or Hungry Jacks is where it's at!
Whooper with Cheese and Bacon or an Aussie burger = WIN!
ahah i had hungry jacks last week and it was actually pretty good!
and the store in bulleen makes you feel like your back in the 70s or something when you walk in, its always dead too lol
Anyone have recommendations for kebab places? Got a craving!
Mitcham Kebabs!
^+100 this.
Place is great, dunno why you guys got sick :/.
That said, I think it used to be better, way way before even the recent move (/hipster), But it's still good - but their new legit premises doesn't have the same feel as the abandoned servo... fit so many cars in there, and could have a kebab and good chat...
Yeah, they need an update but as long as the food still good, it's where it counts.
^+100 this.
Yeah, for sure man!
Mitcham kebabs are over rated. Come at me brahs
Way too hot, burns my hands every time. Also foil is annoying. Oh and they take forever.
Best I've had recently was in Campbellfield with mohomo
go for some tonight? no homo
I asked my contacts. Unfortunately out of their power. Needtogethighercontacts
I'll see if our staff shop has any haha
Please don't play with my emotions like that!
Buy every god damn block im good for it $$$
Limit @ 10 blocks
I
ok so suggestions for head phones
must be over ear
noise canceling.
and I'm running pxc 450 sennheiser ATM, so better than they.
go
I have bose quiet comfort 3 - good travel phones but not sure they will be better than your sennheisers... not sure I have heard any better nc phones though.
haha what happened? how did they send you wrong size? :s
Nah was f**kup on our side, the way the standard lips are to the wider lips we calculated wrong
So new lips will stick out 12mm more than I originally was thinking
bigger is better :D
You would think that, but not if you saw how they fit currently :P
This will be fun.
haha oh it will be ;)
needs way more camber first though :P
Guest
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
