Who is good with wiring and shit? Cluster and window switches died on me yesterday, some chewed wires in wheel arch loom (dat stance) but I joined them together again with no success. All fuses under dash and in engine bay are sweet. Help plz
You should probably check those wire properly and make sure they haven't broken elsewhere/are now contacting properly.
I rubbed through some of my loom and lost my cluster, windows etc.
They only appear to be broken in the one spot, the rest of it seems fairly well insulated. Was it just that bit of the loom that was your problem?
Yep was only the loom, took a spur of the moment late night trip down the GOR. Cluster and electrics died and kept driving, then the car died and wouldn't start back up, ended up getting the car towed to local racv blokes shop and staying in Appollo Bay courtesy of racv. Walked to the shop next morning, taped everything up nicely, tucked the loom and drove home.
With those km I wouldn't pay more than 8k for it.
Yeah I'd always be offering 1k less and never pay list price, it's expected lol
rather pay $10k for this
http://www.bikesales...3624E8&__Nne=15
Too old brah something about riding around on an older bike would make me feel weird / paranoid something will fail when doing 110+
Can't just be me?
Bit more for one of these!
http://www.bikesales.com.au/private/details/ducati-848-2008-12920871?__N=1432%20604%201430%201429%201626%201428%204294967242%204294966239%2082&__Ns=p_PriceSort_Decimal%7c0%7c%7cp_Make_String%7c0%7c%7cp_Model_String%7c0&__Qpb=1&__sid=139F477975AA&__Nne=15
birds have you got full comp on bike? thinking next bike will be well under 10 again and i'll just get third party again (thankfully i had it last time).. cbf paying 2 full comps / full regos
Lol hardtuned meet. Everyone said there were no cop issues, everyone was behaving. So I decided to go. It was really good...
... For 5 minutes.
Then the launch control contest began, and who can do a skid the best. People were actually doing skids, leaving, coming back, and doing more skids..
What a fail.
/csb
... For 5 minutes.
What a fail.
/csb
heard a few peeps got defected. Any confirmation mah nigguh?
Don't think so, it was only a divy Van that rocked up and told people to leave.. I went back in the missus car hoping to see someone face plant a wall, but it was literally emptied.. So I doubt that anyone got defected.. There was a chaser that did at least 6 laps of burnouts lol
Guest
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
