Not wow as in big, wow as in that has to be one of the neatest getting around.
thanks mate, just bought it about a month ago, slowly slowly, hopefully it'll see some track time early next year
Oh...
That's not the 33R that blew it motor at Sandown is it? Sold by Bel a month or so ago?
Correct, as I've been pulling the motor apart, I found a decent sized crack in the block behind the alternator. I think it threw a rod in cylinder 1 =/
So yeah it did get track time and hopefully it will get some more track time when I manage to source a motor
you got me =P
In all seriousness, if anybody has a contact or is selling an R33 RB26, with engine number (RB26-059xxx) onwards, please let me know. I'm keen as mustard to get this thing running!
Yeah, I was tracking that same day with him.
What are your plans? Buy a second hand rb26 and put it straight in? or a rebuild?
If your doing a rebuild, feel free to PM me and I can get you a quote
Also have a mate who has a n1 block in his garage that I'm trying to twist his arm to sell it
Edit: just read your above post
Edited by blah_blah
Damn...Well yeah, at least the rest of the car is clean and straight as!
Well I'm not gonna rebuild it with this block. Depends what I can get really from now till end of year. If I can find a good 2nd hand one, I'll just do a mild refresh (Cosworth 1.1mm HG, ARP2000 rod bolts, ARP headstuds, oil restrictor, enlarge oil returns, baffled sump, new water pump, N1 oil pump, blah blah blah)
If not, then I'll look for a bare block perhaps N1 like you said, new head, new crank, CP+Eagle combo, Tomei Type B and all the rest of the above plus all the other usual stuff
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
