You know a lot of wankers don't you...
You'd probably laugh in his face. Wouldn't be suprised if he showed up at one of the SAU meet's talking up a 450kw stock 32R, how he's the 4th person to install cams in his DOHC V6 commo (THATS 4 CAMS YO!), His mate with a 70's fast back with a "600 cubic inch being built, n/a, and it'll be atleast 1hp per cubic inch", and how a 2JZ swapped 32R (with awd) would be the best car ever and would dominate everything.
Aaron would probably punch him in the face. Hahahha
Hmm lol
They're not arriving :(
Seller canceled transaction on me cause out of stock. Everyone seems out of stock, wtf.
try this guy, these are where I got mine and they came in pretty fast too, not sure if that cheap compared to where your looking but they have stock at least
Tried it last night and works great :)
http://www.ebay.com.au/itm/320862768874?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1661wt_1163
I already wanna go back in time and push his mother down a flight of stairs.
Cannot stop laughing:
HAHA
pretty sure i need a hennessey venom gt
Yeha saw that on fb, looked awesome even though it's super stretched :P
power is insane too
Damn randomly-and-surprisingly-hard-to-take-off screw top beer bottle caps which make minuscule cuts on your hand which you only feel stinging the next day when hand is under water etc.
Eating schnitzel and drinking scotch in Melb Qantas lounge on way to Germany. Another week, another not assembling BBS :down: Mo, need more pics of yours to keep me going.
On another point, quickly finished beer label machine before coming here so plan on producing West Heidelberg Lager (look for it in your worst bottleshop soon) - needs to be served warm whilst wearing thongs.
Also saw a 33r and 32r pulled up by highway patrol near Nismo in Thomastown.
protip
only shit beer has a screwtop
man vs food...
burrito chalange (in knoxville)
burrito:
2 lbs pulled pork (900g)
1 lbs beans (450g)
1 lbs coleslaw (450g)
1/2 lbs cheese (220g)
4 full size tortilla
sides:
1/2 lbs mac'n'cheese (220g)
1/2 lbs bananna pudding (220g)
1 hour
that's a total of just over 5lbs (2.25kg)
never before complete (adam richmond was aparently the first to manage)
how ya reckon ya'd go dezz?
i reckon i could do it
I'll grab them on Monday. Just left work. Let me know your orders and will spend up on mon. They will think I'm addicted to marble haha
I'm totes down for 10, given I instigated the hunt I call dibs!
Hit me bank details if ya want the monies now
/marblejunkie
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
