What about working on those big arse construction vechicles? man went out to the warehouse / yard today (cat) and some of those machines have tyres at least twice the size of me and diffs the size of a bloody normal car. Assume that would be more interesting to work on than normal engines. Cranes / hydralics and shit all over the warehouse to assist lol
William Adams take on a fair few apprentices each year, however I dont think they hire too many from outside the mining industry/experience with heavy machinery to teach them and try and get others up to scratch. Cheaper and easier to train them from the ground up
They have the best looking shopfronts and drive the best cars lol, how can they not be rolling in it.
Yeh agree, my Lexus smashed wing mirror cost 2k for that alone :/
The lol was in relation to pats comment
How do you know it's hiflow?
I hope it wasn't your cousin sitting in the passenger seat saying; "bro that sounds hiflow"
He had a lot of black smoke coming out of the exhaust, so assumed it must be high flow.
we ended up pulling it off, pleasantly surprised.
Anybody have tips for living out of home? I'm moving out next week.
- It'll cost you double what you expect it to cost; budget well
- Establish good rapport with new neighbours
- Bean bags and futons
Guest
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
