I have a feeling mine might be 1ohm stable....
Will need to check, I used to be into car audio a few years go but not anymore. I can't even remember the model of the amp :/
At the moment its 1200wrms @ 2ohm for my sub
Yeah I vaguely remember asking you before. Yeah I think yours was 2ohm. Didn't want to pop your amp with my subs haha
I believe you get a lot better sound per dollar value in spending on setup than speaker models.
Put in the research and time and your average speaker models could sound as good as your higher end models if their setup is done poorly.
I've recently built a decware deathbox II enclosure. Haven't tested it yet though. However it's all wired up.
Anyone have a 1ohm stable amp for me to test?
yeh but see an audio engineers thought process is; "If I can make 'meh' speakers sound like top end speakers, then imagine what I can make topend speakers sound like"
also comes down to the whole not settling for something... i'de rather spend the money and not have a headache..
you'll find the best audio systems are the ones that are LOUD AS FAAARRK but you can still have a conversation with someone...
its just like modifying, once you start you really cannot stop
this was the setup in my supra.. i loved it
Haha that's an epic setup. Do want!
How much that set you back?
Dude I don't want to remember how much I spent on that, had the top line mb quart(when they were actually German and not Chinese) I remember the front splits cost me $1500 lol
Subs I went 10" as I preferred the punchy bass not fully sick Hektik droan bass lol
Just did a quick search on MEA I think it might handle 1ohm not 100% sure though lol
Its a Boston Acoustics GT-28. I remember getting it from the States a while back because down here i think it was $1k plus.
Also went with a Class AB? amp as many of the audiophilists said it had better sub control over a Class D monoblock
It's all over my head now, don't remember anything :/
Sounds like one of those cars where the audio gear is worth more than the car :P
Lol
I'm liking it even more than when I first started looking at the CBR... One of the better looking fronts in it's class imo
Not big on the grey mid fairing, need to decide whether I'll spray it black or red...Also want to black out a lot of the silver (heatshield, sub frame etc) but no rush there....First mods will be exhaust, fender elim, integrated tail light and smaller indicators, as well as a black screen from Charles...Also got some rim tape on the way, but that'll be it for now
Guest
    • On 12th June, the mechanic could not figure out what the issue was, but the car seems to be flooding with fuel. He was suspecting the tune, thus referred me to a tuner. Although the tuner is not familiar with Nistune, last Monday (30th June), he came over to try and re-map it. Despite the tuner trying to completely stop fuel, it kept sounding like it was pushing fuel. Tuner ended up suspecting either the ECU or Injectors. I do not believe the ECU or Nistune is the issue, as the Nistune software reads and communicates properly. Today, I removed the (new) injectors to see if they are clogged or leaking. Surprisingly enough, after those 3 days of driving, injectors 2 and 3 look very blocked. You can see the difference in the picture. I blew a bit on 3, that is why it doesn't look as clogged as 2. I am still unsure if this is what is causing the no start issue, but I am now feeling that I may have bought the injectors and Nistune without the need to do so, as the problem seems to be coming from somewhere else.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
