Edit: wasn't Take 5...but it was "something" 5.
Google says it was if you ignore the new Hershey's bar
http://forums.overclockers.com.au/showthread.php?t=782776
plus a few more links.
Good spot...I remembered the Take 5 name, but Google only showed me the American crap that Nick tasted, so I thought I got it wrong.
Fk I remember it being an awesome chocolate bar. Need time machine.
It isn't crap.... hater :P
just found a recipe to make homemade ones :D
Mate of mine has amex pays everything with it cos it's dollar a point I believe works for him
That's what I do...rarely carry cash and I've got an amex and MasterCard for the same account so I'm still set if they don't take amex
Amex just gets charged a fee but apparently points outweigh the charge I don't know though
Very rarely see fees for amex anymore
Because Mohsen
On a serious note, he probably has to help his gf with her grade 6 times tables homework
:laugh:
Lol at the moment I wish it was that az.
I might come down for a look and to talk some shit but can't be there all day.
At least come in the R32!
Think I've heard it all now.. Guy sellin car private wants xx price + 700 for the rego I'm like lulwut
I said to him soo when you buy your new car from the dealer with 12 months rego you gonna refund me my 700?
Guest
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
