yeah, cos a 360awkw bought not built GTR is not a cheater car but an evo is :P
lol good thing when i purchased the GTR it didn't have 360rwkw then isn't it? :merli:
It also didn't have brakes, suspension, diff x2, larger turbos, ECU, injectors and that's just what i can remember :D
Basically just as i had it as i wanted, you got it
:laugh:
Haha true,I wouldn't have done anything much differently. Only difference, It's just gonna be really really shiny when it's all done :) Been thinking a lot about e85, will see what happens
And a big single...haha
well then im sold on a 7.. not going to go nutz on mods, so dont really need the stronger engine!
and if it does blow up.
stroker.
2.4 stroker are cheaper to build than the 2l lol
Only thing is the 2li is more rev happy
Regarding evo 8 MR, I might be wrong but don't they have different cams to normal evo 8's. I'm sure iv read it somewhere when I was looking into them, could be wrong tho.
Yes they do, but cams are upgraded usually to, especially if you do upgrade turbo
So again, 8mr is really more money for something that has an alloy roof and fancy CF rear spoiler if you plan on modding the car (which you usually will with an evo)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
