I don't find this heat that bad for riding...with a vented textile jacket it's alright while you're moving. But I'm not jumping at going for a ride either...
40 degree days, I've ridden on one of them and, stopped at the lights is your own personal hell.
yeah true not to mention bike will probbaly catch fire lol
very tempted to take it out now eventhough windscreen is off. just washed it looking all pretty n shiz
R6 probably the only side exhaust bike i wouldn't mind having. delicious.
Rode on Tuesday, only get hot when stopped... oil temp got to 106 at the lights but drops 20 degrees as soon as u get going again
Mates gixxers have fans that kick in around 106, not sure if mine has one or what temp it kicks in at
What about the bag of boost alvin? :P
f**k that bag of boost, who wants boost!?!??! i have heaps, come grab them. i want chocolate, not biscuits and sugar.
I'll give you a choco Alvin if you make me some of this so called magical wagyu of yours!
Lol.. unfortunately, this batch has sold out. sorry brah LOL i dont even have any samples left because my scumbag housemate took them all.
You know if Nick's (Arma) 4dr gtir conversion was ever finished after he sold it?
Oh gosh, that's testing my memory. I thought you were asking if Arma finished it at first. To be honest, I have no idea if it was ever finished. There are a number of 4-doors with GTiR running gear getting around, even someone who bothered to do it to an N15.
Edited by llama_au
you got too much time on your hands :P, I had 3 little girls ring the bell, gave them those big caramel koalas
cos im not a flamin mongrel
It's that or give them some of my marble chocolate...
Haha, just thought I'd see. I want to uni with Nick, so knew his was one of the first and he'd sold it before it was completely finished. Was an awesome conversion though, very stock looking.
Haha sitting there at the lights watching the temp gauge go up with paranoia. Amazing what a bit of air flow does, almost instantly. My bike sits around 70 when riding but can get as high as 108 sitting in traffic and the fan kicks in around then I think.
Anyone seen the movie Zombie Strippers?
Friend told me about it and it was on tv before.... little bro flicking through channels and was like wth! hahaha
Huh? It's on channel GO! at 11...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
