that's why you need:
http://www.theverge....-pictures-video
watch with GPS that keeps you always correct..I don't have one but I can see the massive attraction to it
yeah one of those would be mad
Birds, I agree if it even fetches you a few brownie points with the senior dudes in a corporate environment it's got to be worth while. You should always dress well never know who you might meet on that given day.. today was a prime example for me, probably should of shaved though lol
blue accent one looks pretty gewd as well imo.
Edited by kaitoukid
http://www.bikepoint...cs=30&silo=1400
birds dis one, pretty pricey though if he took 9k would be good
Offer him 9k, if you get it for that you've done well. What do R6 go for new?
Serviced by Peter Stevens meh...that generally goes under the cons column.
Hambo - 2 days this week doing 6hr shifts in a kitchen - knocked the stuffing outta me, but must admit I'm highly enjoying it.
Will get used to it in a few weeks no doubt.
Cant wait to get open!
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
