It's not a late fee for paying early, it's because interest is calculated monthly, so if you pay early then your payment will count towards the previous month and technically you haven't paid the current month... Jus made a double pay for the previous month.
^^ yep. The amount of complaints I copped for overdue fees and interest for the above reason pissed me off..
If you don't know how a credit card works, don't get one...
Yeah I know, just irritating as I was paying the same day every month and had been for a while - then one month the day they sent happened to fall after my usual pay day. Now make sure I wait for the bill
Hmm, might forego WP8 for now; let the ecosystem sort itself out and what not...
Maybe even wait for LTE to become a bit more widespread before jumping on to that ship...
And purchase a Nexus 4. @ $399 for 16gb version, don't think could go wrong. Looks like android is imminent for me :D.
Lmao jonoe (or should I say... pho) I saw ur thread when I was lurking jdmst. Took 1/4 ~ 1/3 way through until I was like hold on... this is Jono's lawl
EDIT: ^lol at above... starting with 2 anyway... have be 12 or younger to share a tune ;P
Edited by kaitoukid
Nice coke bottle, what year?
Got no f**king clue. Still got any marble?
LOL. Phoreals? Probably when you saw the pic with the wheels on. Haha.
Dont want to put swaybar on yet, 26mm at front with no sway at back, and fwd, deadly understeer. Haha
oem EK9 Swaybar for $40 with endlinks and bushes. Yiezzzzzzzzzzzzzzz. So cheap! So rare. Such a stealll
Assuming that's a rear swaybar, be careful when you put it on...they make a huge difference to FWD handling and you wouldn't be the first to oversteer off the road (assuming you drive spirited corners).
Is actually front sway bar (26mm).
I wont be putting it on until i get a rear sway bar (24mm) to balance it out. I'm well aware of the effects of running one sway bar, or a really thick one up front/back compared to the back/front.
Will have the swaybars set up so its neutral, maybe a hint of understeer.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
