these will be too big man. wayyy too big..
how is it gayer than mohsen? i enjoy the fact i dont have to be scared of being defected when I drive now.
Ric I didnt even know you had a car til after SNS.. that makes you gayer than mohsen.
You being unaware has no bearing on my sexuality brah
My car is mad
Finished exams yesterday so today I've started work on the gtr again.
Woke up nice and early in the morning, got all the nuts off the plenum
and a few hoses that hadn't been removed yet. Timing belt is off also.
Task is to remove plenum in the car, to my understanding it involves a lot
of swearing but I never thought this much..
How the fu(k do I take this mother of a plenum off? I've unbolted the air
chamber underneath and still no luck. Is it easier to pull them off the throttle
bodies or easier to pull both out together? I can't see seperate nuts/bolt heads
for the tb's so I'm assuming it's just long as studs coming off the head through
the plenum flange.
God and sau help me
Parents cheaped out on you and bought you imitation Lego. Or Duplo, which was Lego for tards.
Had lego lego, had the mates an stuff, just had an imagination and didnt need to be told what to make :P
3 months back I bought the Super star destroyer Ultimimate colletor series
over 4 foot long and over 3000 peices.
http://lego.wikia.com/wiki/10221_Super_Star_Destroyer
instructions come in handy.
not building it till I get a bigger place as no-where to put it atm
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
