Yeh Hambo it was the same reason I went to a 7. Look hard enough you will find a good cheap one especially that everything is interchangeable.
230kw aswell should be a safe comprimise too!
Alex, there is heeeeaapps of room in the evo I reckon it's a good family car. Had my parents in the back and they had heaps more room!
You have to check it out! I seriously think this is the best cars I've owned and everyone around me is agreeing
Yeah they are pretty big inside, boot is huge too
But then it is a lancer :ninja:
yeah, they are surprisingly big,,,
trey on evolutionoz takes the 2 kids in booster seats and a pram around in his VII no worries
also remember... 4 doors for more whores
Aaron might need your guard help on Sunday coming up if end up getting scrubbing, wheels / tyres should be going on saturday
Should be free Sunday morning if you're into getting up early
i'm sure it has enough room in it for one of these babies (no pun intended)
i looked into those... but i ended up with this bad boy
has side impact cushions and even has speakers in the headrest so he can listen to biggie while we drive!
Biggie? Get the lil man onto reggae. Instead of an angry life he'll be jammin
one of my
best mate's boy is a massive fan of reggae. not two years old and he knows which button the station is preset to and how to turn it up.
Yeh but once u add baby seats prams and all the bullshit that goes with it most of the time can't even slide passenger seat back etc
I rkn if I ever have kids will be x5'in or similar for sure
pram goes in boot and i only have 1 kid (well i will in a few days) so he sits behind passenger seat and the mrs cant drive manual so no issues ;)
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
