yeh i registered.. some strange requirements, but atleast it means the likes of NS will be there ...
Indeed... I tried twice, but got an error though :/
Although I did put my lisc. number as 000000000. But the error seemed immaterial to that, so I dunno :/
Such as?
Location (City, State), first name (no initials), car make, drivers license number; must make a non-one-line decent introductory post in intro section before rest of forums can be seen.
Those seem to be it from what I can gather so far. On the one hand, I see where they're coming from, and didn't really mind, but driver's license seemed a bit excessive / I was surprised lols.
Edited by kaitoukid
Seriously?
All that for a godamn forum?
the cressida ones are even better man...
those dudes even have a fake forum with topics about pension money etc set up until you are verified as a member
LOL hahaha
yeah then admin has to approve your registration i'm pretty sure I had to wait like a week for my evo oz account..
Yeah had a feeling prob need admin/mod approval for reg... thought they'd be a bit quicker than one week though. But still... dat security.
Seriously?
Mmhm.
Maybe it's great once you're in though hahah.
wow I signed up when they first got started so they have none of that for me..
I personally would not be handing that info out over the web.
DOB drivers lice suburb..great for identity theft, hope their DB is secure
Yeah that's why I wanted to sign up - lurk and just gain more knowledge in general.
Haha like I said earlier, not too fussed about some things, but yeah stuff like license I was a bit iffy :/
If 000000000 too obvious, maybe just make up some random 9 digit number :P
Yeah, I'm getting some other unrelated error as I first thought.
"Error: ! Anonymous hit limit reached for IP Address xxx.xxx.xxx.xxx.
Why not get an API key? It's free, and it'll allow you to perform a larger number of bot-screening lookups each day.
If you aren't the webmaster for this domain, please tell them about this error message."
Tried resetting my IP to no avail.
Ceebs. More procrastinating instead of studying for exams lols.
Pics?
check fb all there
Well they can't hand out defects for phaggotry
LOL
They were probably in disbelief of the shit that they do to their cars
hahaha yeh..
be funny if they did..
hey nick;
why is it that all the dump pipes for evo's are only 2.5" exit.
isnt that a tad small ? how are these people hitting over 250kw with it?
Zage dumps are the biggest separate dumps, some aren't even 2.5"
Custom is the only way to go anything bigger than 2.5, I was running a Zage no problems.
http://www.ebay.com.au/itm/Turbo-Dump-Pipe-Mitsubishi-4G63T-Lancer-EVO-7-9-Outlet-/281016580474?pt=AU_Car_Parts_Accessories&hash=item416de4b97a&_uhb=1#ht_2015wt_1397
These are Zage ones... Buy here for $15 compared to $300 from Meek
You can go a MAP Performance split dump front pipe, but it is an absolute headcase of a fitting, it's hard enough getting the dump off with the rear nut
The link I posted is the best way to go, unless you go custom 3" dump which for the power your chasing is no point
Guest
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
