7Watt LED's (400 lumen yo!) for reverse lights to help aid my reversing at night with 20% tint.
Stock Halogen:
Stock Halogen (rear view mirror):
LED vs Stock Halogen (Rear view mirror):
Stock Halogen vs LED:
LED vs Stock Halogen:
I feel sorry for people behind me when i reverse. At 10 meters away, looking at the beam of light, it like looking straight into HID's.
$350, yeh, i'll do that...
it's all plug and play with the MR turbo yeh? and all up the front of course
Yeah all plug and play.
Also can just buy a 10.5t housing for the rear and modify the stocko
Thats all that's bigger 7/8 run 9.8t and from 8mr/9 they run 10.5, would be cheaper probably doing it that way but a bit more hassle
pretty tough, people have too much money though
also needs better front tyres and to weight down the front, would be dangerous driving down the road at high speed in it
Our tractor at 30km/h is all over the road, they aren't meant for high speed, especially with skinny tyres
Stock Halogen:
Yeah I've got one in the Golf, works great
My mate, saw a prelude for sale, wanted his lip kit. This is what happened:
bad English is a necessity
i always get buff before i go and see an orchestra
FYI the ACO were amazing...and I'm pretty sure I had the biggest bench press there. Incidentally, the next youngest person was also at least 45 years old.
not the first, but here's another perfect example of a timewaster: Miguelone
i drove 60kms to meet michael 4pm saturday afternoon, 4:30 tried calling, sms, nothing.. come 5pm i recieve an sms 'oh hey mate i can't make it today - anytime tomorrow is fine'
so i give michael my other address 30kms away, load the parts up in my boot and arrange to meet him 10am the following day - to my surprise he doesn't turn up, doesn't answer his phone, doesn't reply to sms, yet is capable of posting on SAU.
people like you ruin this website! i know traders that deal import spares comercially and dont bother with trading online as too many people like yourself!
Rear subframe brace?
Also this bracket & mounting hardware if you have it.
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
