Nah even mine came back. I thought its better like that as everytime u take off/put on wheel nuts it won't leave that scratch mark.
We doing Sunday? Or u gonna wait till next week?
ah yeah fair enough then ill just leave the silver bits
haven't got correct sized rears (wanted 9.5 +30 he sent me 10.5 +35) so hopefully i get the ones i ordered soon for the rear and then i'll let you know if i get any scrubbage
I did however put my small 'sortaflush' sticker on which was intended for nats with these rims / for the lols :( taking far longer than intended to put on lol
just bought these for the hub. rather be safe than sorry:
http://cgi.ebay.com....#ht_1120wt_1155
Yeh good. Lol I had "because too expensive" haha
Hey guys.
Just picked up some BBS RG-R's 18's for new daily rims, and going to use my AVS Model 6's as my track rims for some Semi's...
Where is the best place in the eastern suburbs to get some Federal 595 RS-R's in 2 x 235/45/17 and 2 x 255/40/17 and how much do you think it'll be?
kgo, wasteland contacts, unite!
also try wheel tech in Dandy, looked after me a couple times for rs-r
yeah day was massive, finally found a caltex not on the map with vortex 98 so giving that a try.
nearest Bp is20 min up the freeway.
there was some very very fast times from SAU folk,
richo 2nd Mod RWD
madden 2nd SAWD
ANd 3rd ModAWD behind 2 modded R35
plus I'm happy with my run.
Now just a matter of downing beers to dumb down the brain cells so we can go drag racing tomorrow ;)
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
