Pulled up next to a Ferrari 348 last night. His gf was admiring so a race to the next set of lights seemed like the appropriate thing to do. Even with a noob like me on a 2fiddy the feza had no chance :/
Makes you wonder, what exactly is the point of a 600cc+ bike for road use...
I know 348s aren't the fastest Ferraris around but still
Having said that, I've decided that I'm broke and am looking for an older/cheaper 600. Do like old r6 ~2005 possibly best front end I've seen so far but first mod would have to be a "shorty" exhaust coz them big canons look fkn disgusting on bikes.
/csb/bikes
Little-ish 50km/h road I take every time I go in to work... have had an excel overtake me, casually using the incoming lane (daytime / there's colour lights at the end when heading in that particular direction no matter what lol).
You guys are clearly hoons :P
had some ve malloo with 20s on it try me, smoked that mofo f*kn hard - he mad then get the 'thumbs up, i just got f**ked up..' I always slow down next to them afterwards just to see the look on their face hehe
getting front tyres fitted to rims today, no rears though :(
bahaha i considered it too, but i was in 5th, and too ceebs to prove anything of the like. although one of the few opportunities with my all my killerwasps via na powah XD.
in any case, mismatched wheels, drifter4lyf, m i rite?
I won't be able to do them till next weekend so hopefully they don't scrub lol. I have a christening tomorrow Leigh
Can't actually put them on anyway, because the tyres are fatter and the stock low profiles on the rear = traction control system go crazy
cost 60 dowla to fit 2x tyres to rims? dafaq?
eww.
lol i mek fit fo yu yu gi tertee dorra pe wee
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
