Yeh I pulled the orange lense out. Made a good difference..
Also painting the insides black and cleaned the lense..
Tony, Scott's plans are to get it running for now, but don't think he'll start till next year.. When he starts modding, I guess I will too lol
gonna do the same but i'm keeping the orange and doing the projector lens yellow
JDM33 is now on hold for an interstate buyer, so looking VERY likely to be driving away next week after 7 years :'(
340rwkw by 4000 rpm sounds annoying (in a fun as f**k way)
al's car is hard enough to drive let alone add 100kw by 4000!
because it's auto it requires very little throttle and just purs along < 2000rpm in normal driving and comfortable as love it
on another note, called that guy with cbr600rr but got voicemail :( did 80kg bench tonight :D
Edited by UNR33L
I thought about keeping the orange lense, then I felt like I was putting a chev badge on a Holden. It's an Evo 7, not an 8MR ... Even worse would be the fact they aren't even genuine 8mr lights lol
not removing something is not the same as adding something
EOTD it looks better so ima do it
Up to you. Dependig on the colour you'll figure out what you want to do. I thought it looked better with it removed on a white car, on a yellow car or something it would look better with it there.
Meh I like it without it and its my car lol. I'm not gonna do what others like, ill do what I like
garage ftw yo.
and on another note, its f**king hard to get filter paper in melb... none of the scientific supplies do over the counter sales, its stupid.
Bahaha, unless I need to go out that day! :(
I normally get lazy, wait till it rains and gets it wet... give it a quick going over with a microfiber towel... then go back inside and let the rain rinse it clean.
Ahaha, sounds nice and ez. Should get in on that finishing detailer spray stuff perhaps as well?
I need a good coat of wax before I can do something like this xD. Probs end up dirtier... always does!
Car has had its final tune. 280rwkw. 190rwkw @ 4,000rpm
Come at me Birds and Odium
Maybe not Leigh though :/
I'll race u. NA 4lyf. (Notrly). How's the power with actual driving? Still the daily, right?
So it begins
I hope you guys still have these when I get mine... :D
Who would have guessed you would REMOVE something orange on your car
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
