Hopefully they will go on this weekend if I finally get my correct sized rear rims. Aaron you may need to yell again!
Yeah definitely depends on my foot! Which = 3rd gear power skids.. :D
Birds couldn't get through to him will try again soon
Edited by UNR33L
Should definately get traction with the NT05's + wider rear tyres
Ill give you a run from a roll for the lulz
Yeah should be awesome grip.
Haha if you want :D raced a mates 34 gtt that i hadnt seen in ages with same ammount of power as urs he ended up raging off prinny and went home.. :D
Even from a roll, you'd better be prepared to spend the next week picking rubber off your windshield. :(
watching top gear... s2e6 "both cars will do 0-100 in less than 5 seconds"... s11e2 "both cars will do 0-100 in less than 5 seconds"
this is re: evo vs. sti
good to see progress being made :P
lazy afternoons brilliant.
I think the sti is quicker In a straight line, but the Evo corners and brakes better or something
Noticeably? From what I remember (from various times of reading stuff) it was mainly the sti which was more daily friendly (moar displacement, stuff like cruise control) whereas evo was more responsive to mods and won the performance stuff?) - but don't recall straight line info (I guess no one bothers with these when they can turn so fast? :P).
I are dad
o shiet. congrats man!!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
