Just saw twilight. Was getting pretty good towards the end when everyone was dying and graphically getting their head ripped off and fkn burnt...
Nek mennit
It's a fcking dream.
Worst. Episode. Ever
Nek mennit
buys evo
nek mennit
watches twilight
thats all the evidence i need!
Haha fags, I have a gf, not a boyfriend like all of you fags.
And unlike all you heroes, I can admit when I'm whipped.
Remember a girl really has you under her control when she has you thinking your not under her control at all
congrats!
cant find a decent link, but Road Track Rally have almost finished their new skidpan, if anybody didnt already know...
10mins from Melb. http://www.facebook....&type=1
Dandenong is as close to 10mins from the CBD as Niroj is to white.
woouldve been awesome if it was dandenong, although i dont think local council wouldve been to happy with it.. place is f**ked up as it is, let alone attracting revving skids etc..
Agreed. That's gonna be the main issue. Look @ the skidpan @ Drag Tag, coppers ended up just sitting outside the place constantly anytime people were using it.
Given the main business of the RTR owners is forklifts etc, it's clearly being built as training for that... So council/zoning would have no problems. People coming out and doing skids and stuff the like, that is an entirely different story.
I really hope that doesn't happen here as more places the better without a doubt.
Admitting you're whipped doesn't make it right lol.
never said it did, but like alchos and drugs. the first step of fixing that issue is admitting the problem..
means im one step ahead of you fags
plus as if you can talk white knight
To hell with the world, I can make my own people.
this is true. mate of mine has completely lost his social filter after having a kid. not that he had much of one before hand
lol. frankston is more appropriate
one step ahead of single guys in not being whipped?
aaron pls
lol I've been in and out of relationships and arrangements, never been whipped by a girl whether single or taken. Black knight motherf**ker.
Aaron pls
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
