Anyone know if a R33 airbox will fit in a R34? wanting to hide a pod and not sure if the size of the 34 box will cut it :P
Nope, R33 are wider, discovered that years ago when a bloke with 34 gt-t wanted to buy my ARC airbox. Washer bottle or radiator overflow bottle in way.
105kg x 10, nothing to sneeze at, but nothing particularly strong either. It looks like a lot of weight, but for my bench I should be doing at least 170-180kg x 10 on deads.
And yeah I'm feeling like a Krispy Kreme. Shower time.
Had some Krispy Kreme last night. Feelsbatman
Got defected for pod, took it off realised it was drift, gave it away.
Wanting to buy one of those HKS mushroom pods from FRSPORT.
But was waiting till i found a suitable airbox to cut open before bothering.
/end
Honestly, you'd better off keeping stock airbox and chuck decent filter in i.e. K&N, BMC, etc
Was told they makes same/similar induction noise as pods, someone can confirm.
/end
They don't call the HKS filters "poisonous mushrooms" for nothing...
They tend to break down over time and send shit through the turbo/motor.
Looks like everything i plan/do is terrible, so gonna sell the car and get a myki
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
