Night rides are much nicer imo
Shame you can't get too comfortable with all the idiots driving around
I love riding at night. It's in some ways safer too, what with lights and shit...but also more likely to come across drunk drivers or people assuming there's no one else on the road.
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
