Thanks for chocolate ideas. Have passed them on in our brain storm session.
Aaron want choc for tomorrow? Can get a box of flake for $40 if anyone wants to split the cost?
How big is a box? May get you to get me one separately...
When a mate of mine (cop) used to get cadbury factory seconds they'd be like 30cm x 40cm x 50cm and the box would have a bag in it which 2/3 filled the box with unwrapped chocolate…. Boost etc...
tl;dr
Ferkload of chocolate.
im personally alright bro..
i think im made of enough chocolate as it is..but thanks!
tl;dr
Was that Declan lol?
3 hours or something of driving the rx8.. 2-3am f**king zombie mode, I had left my car at hers, dropped her off jumped into mine, drove home, 100kph, trying to get into "6th", it wouldn't, so I kept doing it and eventually forced it in, let go of the clutch pretty quickly, BANG! Never reversed again
Your standard shop box which I think has 40 wrapped bars?
What else can you get, might buy a box so my old man actually has something to eat during the day in the truck
Might slow down the consumption of cigarettes and coffee during the day :P
$40 for 40 bars? Fark what happened to the discounts :(
$40 for 50 wrapped bars. Less than $1 each. in stores is always more than that.
Unwrapped bars in boxes always sell for cheaper as people can't resell them easily :/
Haha they would melt in the truck :P
Sorry left work now but can get some for next week if coming.
Did you even see my russian chocolate cheese suggestion? :P
haha I wouldn't have them all in there for him lol
He doesn't like flake so much, so let me know what else
What's on next week?
Yep, Honestly don't know how he stayed in shape with all the Boost Bars and Dr Pepper slabs he used to have each month, lol
Haha used to work with him at Coles before he joined the academy.
Oh and, then there's primary school lol.
Fair call, I guess with 50 bars that's pretty cheap.
Guest
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
