Coilpacks are splitfires with maybe 30,000k's on them
Technically they should be able to spark a 1.0mm gap with no issues. Unless you have some awesome knock issue that's squashing your plugs shut. But doubt it
Swap your coil packs with Birds and see how you go
You guys pretty much live next to each other
Yeah, or you could volunteer your own coilpacks and time!
You wouldn't want my coilpacks for testing, I actually need someone else's to test an issue with mine :/
Coilpacks can fail after 500km...defects happen. Could also be an issue with your coilpack loom.
I do have awesome knock issues :/
During the tune Trent said he had to pull a bunch of timing out of the top end to battle the knock... Then at DECA it was stuttering up high when I was boosting hard in 1st / 2nd.... On the pan I had to keep it in 2nd so I wasn't limiter bashing 1st...
I saw the engine check light flashing... it got up to 65 knock, a week after the tune. in maybe 30c heat after less than 30 seconds of hammering.
More than a little worried about Sandown tbh
Fark I might be fuel actually.... It's not the same kind of power drop that I experienced when my stock coils died...
Fuel pump is an in tank Walbro.... I think its a 255L pump
AFR's on the tune looked alright, I'll upload a pic of the AFR graph when I get home.
This is the misfire when my coilpacks were dying.... The power drop is similar, but no sound, which would make sense if there was spark, just no fuel to burn....
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
