Hey everyone, i know this is going a few pages back... but regarding coil packs and issues with them; Mine on my R34GTT seem to have started playing up (shaking, mainly noticeable on idle) and car has far less power than normal.
This happened to my previous R34GT and i replaced the whole lot with Yellowjackets, this fixed the problem.
I've ordered some replacements but my main concern is if i'm doing any damage to the car by driving it around before i receive/install the replacements.
Because i know there's a problem i am driving it like a nancy boy as i'm worried i'll screw something up.
I'm assuming that your first port of call was changing spark plugs?
If the coilpacks are on their way out, and they are bad enough that its not idling right, it will def be missing on boost and you'll hear a bunch of misfires through the exhaust.
I'd change plugs to a $25 set of Copper plugs and see if the problem persists, before spending $$$ on new coilpacks.
What mods? and what plugs are in it atm?
Thanks for the reply mate,
Have changed the spark plugs with no avail (problem persisted), definitely missing on boost but once i noticed something wasn't right i didn't really want to push the car too hard.
Only modification is adjustable coilovers, apart from that it's completely stock. Plugs are factory at the moment.
I'm fairly certain it's the coil packs as it feels exactly the same as my last car's issues
Hard luck Tony. I know how much time you put into that over the last few months! I'm waiting for someone to steal my car (secretly wishing)...seems only to happen to the people who don't want theirs stolen :/
On the brighter side, you can upgrade your daily earlier than expected...
Sorry to hear man :(
all it needs is tyre level with guards front and rear and will be perfect :)
how much low will I get from eibach springs? I would like to drop it only like an inch on the stock coilovers... want this one to be legal as possible
this... oh god this!
Pulled carb apart and got busy with the carby cleaner
Fixed the out of tune jettings
Replaced the ridiculously restrictive air filter with just mesh
Idle's now more stable
Throttle response improved greatly
Sound is now even louder/better
Might aswell service it too while it's stripped
Don't think neighbors seem happy though apparently 15k+rpm at 11.30pm is breaking some law
the smackdown... embrace it
Hey Scott's gonna be making a 3.5" dump an front pipe(2 piece) for around the same price of all the other combos.. Would you be interested? Coz then that's 3 of us
dunno man... I was planningn to buy second hand so it's cheap and doensn't have ANY shine to it
Don't go too low, evo handles great from stock, so any lowering is purely cosmetic / anti-4wd jokes.
An inch is about perfect isn't it? What wheels are on it?
yeah, that's what i'm after... about 1"
rims are KOYA RG Tech (Advan RG ripoff's) 18x9.5 but unsure of affset untill i take one off... looks to be approx +20
Up to you..
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
