Nah shouldn't be as long as u don't block the plate
Like those afl logos and that
SES member raised a good point - from a distance those stickers look like LPG stickers, so if you're stuck in a burning car you might not get help as they'll think it's going to explode
This...
EllllPeeeeGeeee!
Tony I'm keen as to see the footage, I really hope someone knows this f**ker so I can punch holes through him
Only cops can access footage. Wont get it for a while
Might have to look for a new car
I hear there's an Evo 7 with pretty good compression test results. Better go quickly put down a deposit
All that work put in to it recently Tony, :(
So if it's somehow recovered (without damage) - what happens there? Do you get it back if you want it? Any sort of compensation etc?
or join sau team evo indeed.
too late brah
Guessing just cars will just put it up for auction
too late brah
Damn!
It was travelling down Wellington on the wrong side of the road, that's not professional car thief behaviour at all. Thats an amateur fo sho.
Did the CCTV come up with anything interesting?
Not really guy just buying smokes. Apparently stood around for a while.
Paid cash. 34 litres
Only the police can request copies of the CCTV footage
But the manager said the guy fit the description and also my car. She said there is a clear view of his face
Guest
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
