oh my bad didn't read that properly, well you'll see my brother at Goodlife! drives a 33gtst
Matt was just trolling around all over the place
Edited by UNR33L
You'll see me and Birds down there then :P
No he won't, we're Genesis fool.
Ahahaha. Too bad, could've learned from you 'masters' ;p
On the issue I was talking at before, looks like I'll probs get my order cancelled and refunded... had a quick read of the site's ToC's (unless they were just updated haha... but doubtful) - and it more or less covers them in cases like this.
So I guess the answer is it depends on the site/company's ToC... basically I think most will have ToC's that state your 'purchase' is rather an 'offer to purchase' until confirmed (and may also have a separate clause for pricing errors) - and they are within rights to not sell it to you (I believe after they have sold it to you, it's too late unless they have some other clause).
Mmmhm. Sadly probably no $9 suits for me hahah.
Went for a ride out the track?
Yep sure did, almost threw up by the time we got back, not a good idea to not drink anything until 2pm and then go 180kmh around a track on a hot day!
Sure was, too busy lolling @ the R Motorsport GTR in the parking lot.
who you go for a ride with that was that slow?
Someone who couldn't put his foot down in 4th without running out of fuel pressure, mother f**ker :P
If he felt sick after laps with me... Imagine him with you or paul or richo....
So apparently there are cars called the Mitsubishi Lancer Evolution VII and I have heard a rumour that they don't handle very well around corners....
I decided to take it apon myself to do some research and document my findings in a short film that I like to call "Sandown Session one Lap one Turn two, How embarressment!"
I didn't puke, so all was good :)
Okay, so he's at least turning through corner 1 now...just gotta work on corner 2 and so on until he's familiar with the layout :P
LOL as if I was, fixing my hair maybe - nohomo
but yes I was there, were you one of the drunk dudes hugging a dude peeing? lol
I was the guy to your right blowing his nose.
You wouldn't have seen me as you were captivated in your reflection
hahaha fair enough, should of said hi! how'd you go on poker anyway?
Wasn't really sure if it was you so yeah
I wasn't playing, just went there to meet up with my mate who was...I played a few hands with his uncles cash when he went for a piss and finished up, so I went well if you count that lol
The suspensions completely f**ked now. Strut tops have completely torn out and grease is coming out of them :S
Tyre pressure was way too low.
Even John Richo drove it and is it was hard to drive.. Guess I gotta learn it abit better
Me two haha. I am not a good passenger. Went in a 500hp 996 Turbo for instructors lap
Even taking laps slower than my own driving I felt like throwing up.
So no more passenger laps for the rest of the day!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
