Broke yours?
I need to fix and re-paint mine...
Not exactly broke but the car is so low that I scrape a lot and its worn off the whole lip underneath and is starting to get a little weak - it looks so nice at the height it's at but I guess that's what I get :/
You going to paint white man?
Yeah, it's annoying isn't it? The price you pay for being loooooooow
Yeah, going to repaint mine in same white, instructed not to paint it black.
I do wonder what $20k will buy me for my R... LOL
contemplating just selling now and getting a work car.
cbf anymore seriously just cbf.
should of bought an xr6t :P
why not just drive a merc around?
Edited by UNR33L
Yeah white lips look good - problem is those chips you get - carbon maybe? :P
Lol I know I have like 10K worth of things sitting in my rhdjapan basket just waiting for payment
No carbon cos with my bumper vents, black lip will look out of place. LOL'd at 10k things in rhd japan basket. I've got exhaust coming for it, suspension tops and maybe a set of coilovers and is in need of decent radiator, clutch and tune. That should do me fine for a while...
That's what I'm going to do, I cancelled the app because I bought the Evo, so I think I'm gonna go put the form in so I can have one for jan/feb latest
Work blows hardcore.
So slow no one can be ceebs being here. Plus all the birds are wearing those riendeer ears with bells on them. Constant jingling is doing my head in.
Go f**k one of them
About to head to work, should be fun entertain idiots who are too lazy to use their f**king eyes.
Hey baby you wanna help Santa cum only once this year.
Office broad minded persons will love it.
haha if they are anything like the wimmin at my work, termination of employment is worth it lol
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
