i didnt work today my foots been hurting for a few days, went doctors, stress fracture =/
No good man!
Quick question, might do all ancillary belts on my car as they all look worn, has the timing belt been done at all while you owned it? I assume no but I haven't checked yet.
No good man!
there is a sticker on the cam cover saying something about 100K - i thought that was saying it had been done pre-import not sure what it means - though i did a full 100K service which included timing belt and all those other bells and whistles too
Edited by bluejeans
Mate just bought an RX-8 took her for a spin.
Was okay.
If you're a hairdresser.
Yeh my Missus has the rx8 GT 2nd gen. The last one actually. Bit slow, but I still like it. Great fun to drive
When 100k service is done, they place a sticker and hand write the date and actual kilometers done.
The sticker you may be talking about is the one which says to do service when reach 100k
lol prob the 2nd one then!
cant remember seeing a date etc
Ahh okay excellent, do you remember roughly what kilometres that was done at? I just ticked to 150,xxx so it's on my mind :P
farkin christmas presents. Could have spent that money on something more useful.... like on my car :turned:
Good thing no one in the family wants Xmas presents...
More money in le bank account.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
