farkin christmas presents. Could have spent that money on something more useful.... like on my car :turned:
On another note; found 55pounds from last holiday on my prepaid travel credit card. winning!
Man I'm watching my bank account drop its fkn annoying. Especially that I only get paid monthly.
Yeh my Missus has the rx8 GT 2nd gen. The last one actually. Bit slow, but I still like it. Great fun to drive
Yeah I didn't mint it to be honest, he's a very big unit though so always good to give him a tease about it. Looks very funny driving it.
It was pretty quick, handled very well I thought. Definitely not used to that sort of power delivery though. Reckons it does 0-100 in about 6.2? Or something along those lines. Found that pretty surprising but I'd be keen to see what it can do on a track.
Ahh okay excellent, do you remember roughly what kilometres that was done at? I just ticked to 150,xxx so it's on my mind :P
im pretty sure it was nearly spot on 100K
ahah yeah i can understand :P
im about to start collecting parts for my next 100K
I think it takes a little longer than that.. But yeh I'm really keen to throw it at a deca or something but she'll never let me lol
Just an update on the car
Looks as though the theif thrashed the car on 91 Octane which may have led to the car breaking down
No biggie engine is covered under insurance. So rebuild here I come
Not yet.
Still waiting to get the car inspected by justcars, then Im going to get it inspected independently.
Process might take about 2-3 weeks as everyone is closed or on holiday.
Mechanical is covered under insurance, so if its a blown engine then yeah new engine rebuild
Had a rolling with Leigh...1.5 car lengths, I'm happy with that!
Lol we gotta go for longer next time :P
good fun though, makes me want to go out looking for races tonight - would be interesting to see flat road and like a 30km/h roll on I reckon! let me know if you feel like shenanigans later
Edited by UNR33L
Not yet.
Just abit worrying that if they see manifolds hi flow intercooler etc and then not cover it.
lol do it
personally im prob going to go for -9's
Then I'd need to get bigger injectors, up rated afm, clutch, and spare $ for rebuild in case mine dies...
Not a bad way to piss money down in the drain!
Would if it wasn't cop season...get the feeling the defect squad will be out in force with holiday season. Gotta protect the people from front mount intercoolers and paint chips.
Not yet.
if your mates with a mechanic might walk away with some forgies haha
I was thinking of heading down Prinny (bro) later with a few of the ford forum boys, but yeah they'll be major cop action later.
For those of you round Donny (bro) there were a couple of HP cars between the Blackburn Rd exit on the Eastern and Doncaster road. On the access road.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
