Gotta love when your wheel has rubbed through the plastic guard liner and into your wiring loom, hope the part it chewed up was for HICAS or something else I don't have.
happened to friend's car. His fuses kept blowing. Had a look under the guards and the wheel had destroyed the whole loom. Rewired through the engine bay, s'all good.
That FT86 has a comparable power/weight ratio to a r32 gtst. I expected much better :/
FT86
power: 147kw
torque: 205nm
weight: 1250kg
power/weight: 117.6kw/tonne
R32 gtst
power: 158kw
torque: 263nm
weight: 1320kg
power/weight: 119.7kw/tonne
Integra Type-R (DC2R)
power: 141kw
torque: 178nm
weight: 1087kg
power/weight: 129.7kw/tonne
lol tony and john. both fags
i tucked mine up further into the guard. no problems
FT86
power: 147kw
torque: 205nm
weight: 1250kg
R32 gtst
power: 158kw
torque: 263nm
weight: 1320kg
power/weight: 119.7kw/tone
That's pretty poor considering you comparing it to a 20 year old car
That's the non turbo version though,
So IF they do a turbo you want to hope it's doing over 210kws at the fly
Yeah I think I'll do that on the weekend, bought it up a cm or so in the front so no more scraping, doesn't look quite as nice either though. Looks like nothing has stopped working though which is good.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
