Yeh the engine is, everything else seems to fight over what wants to v the weakest link.
But in my case the engine decided to fight as well, spun an awesome bearing
Put it this way, I sold with without an engine.
$10 says you sold it cos it needed an oil change
From this:
To this:
Notbad.jpg. Feels a lot nice to use. Is a bit smaller too so helps with my long lock to lock when parking.
SRS light is on though, cause i turned it on without the airbag to see if it was straight. Now to find out how to reset the srs ecu...
I would assume same as Skyline. Remove earth from battery, pump brake for a little bit so all residual power gets used up, then connect it all up again.
http://www.youtube.com/watch?v=FpWwvWgQ0o4
Came across this board when I was browsing through youtube. Get's a bit repetitive after a while but gave me a couple of laughs. Watch if you're board and have nothing better to do with your life....*sigh*
well if you spun a bearing...you would ahve to change the oil after that..taking the engine out to change oil was probally a little much, and being too lazy to put engine back in as it fell down the back of the couch...
so yeah oil change it is ;)
front lower ball joints cannot be replaced separately, the whole control arm has to be changed. uppers too 500$/control arm?? i dont think so.
Saw the up to the Mario Kart bit and was like wth.... as if they would use Mario Kart and air it until i read the description... lol
Aaron!!!
I got my GoPro3 Aaron edition today! She's such a black beauty!
Know anywhere to buy the suction and pole mounts for cheap?
keep the standard kit on the sedan steve, some 10+15s at the rear and slam it.
i test drove a 6 speed na supra for a mate, was reasonably quick for what it is, but the thing i fell in love with was the gearbox!
Aaron!!!
turn the tables on aaron and steal his ones, bet that nigga wont expect a white boy stealin his shittttt
Dow shift is Asian, Teds usually stocks them, as with Harvey Norman, but I got mine off the site and combined the shipping
And make sure you update it before using it, otherwise it locks and its a pain to reset
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
