And make sure you update it before using it, otherwise it locks and its a pain to reset
I updated after using it and playing around with it... no problems. :rolleyes:
Ted's is expensive... might go to JB HiFi.
Btw, are you using the suction mount to mount it on the gokart or do you have the handle bars mount?
I have a suction mount, currently it's stuck to my bedroom door and I'm using it as a towel hook hahahaha
then 'accidentally' leave the go-pro on, when the missus comes over...
... i c what u did thar aaron
Let me know how much u find the handle bar one for.
Saw it for like 20-30 but not all stores have them, every store has limited of different stock.
Went to 2 JB and 2 HN, none of them have the suction mount..... looked on the system and only HN in Frankston has the suction mount in stock... was looking forward to playing with gopro. :verymad:
oh well, I'll just do some selfies.
I'm not too far from franga maybe I can pick one up for you?
far out
my dad got a panasonic blu ray player and pvr in one
on the box it has plays divx/mkv and records tv
MY f**kING ASS IT DOES
this product is the biggest piece of shit i have ever seen
shitter than the pioneer vsx-527-k
this thing
wont play xvids which is basically the standard these days and the same for mkv as it;s just a container
so essentially out of about 25 movies i copied for him, it only plays 4 that happen to be mp4 mpeg4 format
and it has to be via DLNA so it expects the pc to do the transcoding on the fly
so basically you hit play wait a good minute or two for the transcoding to buffer enough then it plays
WHAT ASS
the WD TD LIVE is absolute god compared to this device
oh and it gets worse
it has USB on the front so if you plug in your own USB drive it has to "register" it and format as linux ext2
so then you cant just copy your own movies to it and play movies off that, played divx movies must be off the network via DLNA
why design it like that
ASS
Guest
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
