yeah it doesnt worry me cos its my dads
he loves recording free to air stuff so he can put up with the ass features =)
ive got two wd tv live's in our house
bulletproof and plays every movie
ive even got two cisco switches now so its a pretty good setup
14 active ip's in my house =)
About to watch The Hobbit...
Watching at Doncaster shopping town... A note to any low brahs... Go up straight to multilevel. f**k the area outside the cinemas. Speed bump + humps are like freaking spikes in NFS, dat scraping :(
Wait till you go down the exit ramp bro. Scrapes like a mofarkin hustler.
Always get scared of the ramps in the Kings Way carpark at crown...never scraped once though. Deceiving.
Wilson's Parking on the other hand...owe me about 5 or 6 front bars.
Yeah, it's bad up there. Hadn't scraped on any of cars I now have and had.
Good thing I don't have to park all the way up all the time since xmas is over - easier to get parking closer to work.
I'm not too far from franga maybe I can pick one up for you?
Let me call them directly tomorrow and check if they have it, then I'll collect it from you at go karts. :thumbsup: That reminds me, i need to pay for that!
So.
I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee"
and i'm going in full formal, is that a right decision? tie blazer and all dat.
Intern at HR company hide all peircings and that butterfly tattoo.
but in reality your going for a job at a i'm assuming professional company, you should suit up as ther a good chance that what you will be wearing on a daily basis.
So. I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee" and i'm going in full formal, is that a right decision? tie blazer and all dat.
http://youtu.be/6Dtn4kP7lrA
So.
Is it a city job?
Suit up bro
Like Martin said likely you'll be wearing that everyday
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
