yeh, but 230 kw is eeeeeeeasily enough to skid a gtst and you can spend the remaining coin on trackdays/tires etc
and you can tell hwp to smoke your pole if they EPA you....
pretty much what I do now, dat feel is pretty good
(nek minit fined for fog lights) LOL
Edited by UNR33L
Might get intercooler, run a smaller pulley and e85 down the track, however then I need injectors and fuel pump as well which is all $ and don't think the change from 370 to 450 odd would be that different.. would get me dat 10 though best someone has got with a tune only is 11.3 down the 1/4 mile with good tyres
Or perhaps it's time I save for a house :(
Edited by UNR33L
I'm thinking a shed, I need to be able to store at least 4 cars, preferably more!
I'm limited by my sloping block, designing a 6x9 with extra height to stack cars with a hoist, so should fit 3 with storage
lol... do you NEED a 10?
370 is stupid power! why risk blowing an engine on a 50k car for extra power that you wont be able to use?
don't you hate it when you've lost the rear end (more than once) on your FWD when out on a track, later find out the previous owner hit a gutter a few years ago and knocked one of the rear wheels out.
get it measured up at Tyre Factory when they were doing other work and find one of the wheels to have 6mm toe-in and the other 1mm. then take it to Centreline Suspension (more than reputable from what I've seen/read) and they measure 1mm toe-in on both rear wheels........
grrr
My Pulsar also had near on 0mm toe in on one side and 6mm toe in on the other side - as you know that is within Nissan spec and the only way to get it better is to bend the rear beam. It almost always has nothing to do with accident damage - that's how they came out of the factory.
I agree it makes the car very unstable particularly with quick changes of direction. Could best describe it as crabwalking. Noticed it at turns 11 & 12 at Sandown more than anywhere else.
Edited by llama_au
One day I NEED that 10! :P
Edited by UNR33L
ETA for BRZ is now April, oh yeah! Nearly time for nervous butterflies.
That's quick! What happened to 12 month wait? Our 18 month wait for 86 has been upgraded to ~6 months too.
So you can be free?
yes.
Polo TDi...I'm impressed. Averaging 3.4L on the freeway. Could get to Sydney on $60.
yeah that would definitely be my car of choice if i were to go down that path, love the golfs are the GTI much worst?
Golf GTI is a great all rounder daily. Great tuning potential too. For the money though, Polo kicks ass. Turbo diesel moves off the line and the 7 speed DSG helps. Would get one if it was a bit better looking, but compared to others in the same market it's probably the best looking.
Guest
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
