Fk going to these places, my tailor flies into Melbourne, takes measurements, goes back to Malaysia and sends the suits back over.
Higher number doesn't always mean better quality, just refers to fineness of the thread. There are plenty of 130 suits that are better quality than super 150, they'll also wear better. If you have a job with a lot of moving around, you don't want to be rocking super 150...feels great and light, but you'll wear it out in no time. I tend to save that grade for special occasion suits, weddings etc.
/suitlinesaustralia
This guy knows.
Didn't buy suits for daily use so should be fine. Got 2nd pair of trousers too incase of any wear.
Pfft what? As if you like getting dressed up? It would be ok if I didn't have to do it everyday. But fk it's annoying, I look forward to getting home and getting out of these clothes
I like wearing a suit...but I don't have to everyday, so it's a bit more special that way.
Also, have you had a proper tailored suit made up for you Aaron? Cause there's a huge diff in comfort between off the shelf and made to fit.
This guy knows.
2nd pair of trousers always a good idea
I've ripped the pants on almost every suit I've owned :/
Could be right, never really bought a tailored suit, but never really felt like I needed to. Al is right you do get treated differently, even in business shirt And slacks, but I just don't like them. I wear the work vest over the shirt for work just because I hate it that much.
Perhaps my opinion would differ if I had a gym body lol. Dunno..
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
